I have ArcGIS 10 installed on my computer connected remotely to my companies license server. Everything has worked fine for months, but within the last few days no geoprocessing tool will run. The results window just shows the dreaded 99998:Unexpected Error. Looking further into the log file I get this:
Job Catalog initialization failed. Directory C:\Program Files (x86)\ArcGIS\Desktop10.0\ArcToolbox\server\system\jobreg\ not found.Server Object instance creation failed on machine KYLE-PC. Job Catalog initialization failed. Directory C:\Program Files (x86)\ArcGIS\Desktop10.0\ArcToolbox\server\system\jobreg\ not found. Configuration GPJobServer.GPJobServer can not be started.Configuration GPJobServer.GPJobServer can not be stopped.Warning: Changes to server object configuration GPJobServer.GPJobServer could not be saved to disk and will not be available when SOM restarts. Reason for failure: Operation on file C:\Program Files (x86)\ArcGIS\Desktop10.0\ArcToolbox\server\user\cfg\GPJobServer.GPJobServer.cfg failed. File not found.Does anyone perchance know what might be going on? Where did the jobreg file go? Do I need to reinstall the software? This all happened completely randomly, and I never touched any of the AppData files, nor the Program Files.
