I have been trying to find out how to make the SAGA and GRASS kernel density tools work in QGIS 2.8. I have had a lot of trouble trying to get them to work as they produce useless results seen below.
GRASS' v.kernel gives me a solid black square with one upper value and 'nan' (the red box is the region). I have searched for reasons this could have occurred and found this. It says the likely cause of error is my regions' number of columns and rows. In my case, I have tried numerous variations in the number of columns and rows and have not found any change to the results.
In SAGA's KDE, I get this weird 4 square result with only two values for the black and white squares. Each of these squares extend to probably 1000x the size of the point data and I'm unsure as to why. Also, is there a way to perform the analysis with no weights?
I need one of these tools to work because the heatmap plugin can not be used in processing modeler and I need to automate maps for people who do not know how to use QGIS/GIS in general.
