I have a sewer network represented as a connected pipelines in a GIS shapefile. the network is very close to a tree graph that each node is only connected with one or two nodes. I need to reconstruct the layout of this network on another program. I first used vertices to points feature to specify the start and the end point of each line. However, this doesn't help too much because I need to specify which node is connected to which node and the feature of the line that is connecting these two nodes like its diameter or its FID for example. I hope this was clear thanks in advance
