I am writing a model that takes a polygon shapefile as input, converts it to polylines, explodes it to individual lines and finally applies a (tested) style, khLineLength1.qml, which labels each line with its length.
Here is the log:
Algorithm Polygon_Sides starting...Prepare algorithm: QGISPOLYGONSTOLINES_1Running Polygons to lines [1/3]Parameters: INPUT =C:/Users/DAZ/QGIS_maps/Kaihu/epsg3706/routes_PG.shpConverting outputsOK. Execution took 0.187 ms (1 outputs).Prepare algorithm: QGISEXPLODELINES_1Running Explode lines [2/3]Parameters: INPUT =C:\Users\DAZ\AppData\Local\Temp\processing\98fbdd36b519415f9e9bc25e9939916d\OUTPUT.shpConverting outputsOK. Execution took 0.234 ms (1 outputs).Prepare algorithm: QGISSETSTYLEFORVECTORLAYER_1Running Set style for vector layer [3/3]Parameters: INPUT =C:\Users\DAZ\AppData\Local\Temp\processing\140dc16954394bd58455470538e300e9\OUTPUT.shp, STYLE =khLineLength1.qmlConverting outputsOK. Execution took 0.123 ms (1 outputs).Model processed ok. Executed 3 algorithms totalConverting outputsLoading resulting layersAlgorithm Polygon_Sides finishedAccording to thishttps://docs.qgis.org/2.6/en/docs/u...tor_general_tools/setstyleforvectorlayer.html the Set style for vector layer algorithm should have a definable output Styled layer. The modeling dialog is allowing me to define the parameters Vector layer and Style file but that is all.
To clarify: In the modeler, for example, when I edit the Explode lines algorithm, I see a title Output layer and beneath it a box with the hint [Enter name if this is a final result]. I do not see this for the styling algorithm and this seems to 'dead-end' the event sequence, preventing rendering and disallowing further styling and the successful execution of any subsequent algorithm.
This is a 'first experience' with the Modeler. Apart from 'little grey cells', what am I missing here?
Here is the log:
