Have just installed newly released QGIS 2.0. I installed the gdal package available at the official kyngchaos site. It seems to run ok, but when the program loads up I get a lengthy error message below. I tried this method to correct the Python path detailed by Carlos Grohmann to no effect.
Error message:
Couldn't load plugin 'processing' from ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/robinedwards/.qgis2/python', '/Users/robinedwards/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']Traceback (most recent call last): File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 182, in loadPlugin __import__(packageName) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import mod = _builtin_import(name, globals, locals, fromlist, level) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py", line 20, in from processing.tools.general import runalg, runandload, alghelp, alglist, algoptions, load, extent, getobject File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import mod = _builtin_import(name, globals, locals, fromlist, level) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/general.py", line 29, in from processing.core.Processing import Processing File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import mod = _builtin_import(name, globals, locals, fromlist, level) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 52, in from processing.admintools.AdminToolsAlgorithmProvider import AdminToolsAlgorithmProvider File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import mod = _builtin_import(name, globals, locals, fromlist, level) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/admintools/AdminToolsAlgorithmProvider.py", line 19, in from processing.admintools.PostGISExecuteSQL import PostGISExecuteSQL File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import mod = _builtin_import(name, globals, locals, fromlist, level) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/admintools/PostGISExecuteSQL.py", line 32, in from processing.admintools import postgis_utils File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import mod = _builtin_import(name, globals, locals, fromlist, level) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/admintools/postgis_utils.py", line 39, in import psycopg2 File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import mod = _builtin_import(name, globals, locals, fromlist, level)ImportError: No module named psycopg2Python version:2.7.2 (default, Oct 11 2012, 20:14:37) [GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)]QGIS version:2.0.1-Dufour Dufour, f738351Python path: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/robinedwards/.qgis2/python', '/Users/robinedwards/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']The Python console in QGIS displays the following:
1 Python 2.7.2 (default, Oct 11 2012, 20:14:37) 2 [GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)] on Robins-MacBook-Pro.localIs there a way to correct the QGIS's python path to use the OSX (10.8.4) default? Or is this unnecessary? numpy loads in the python console but e.g. scipy does not..
Thanks in advance!
Error message:
Thanks in advance!
