I am writing a Python toolbox with (among other) 3 parameters: 2 boolean (check boxes) and 1 string. The string parameter's properties depends on the 2 booleans' value:
Working the other way round (string initially enabled and required and changing its state if the booleans are altered) would be fine too.
def updateParameters(self, params): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" if params[1].altered: # first boolean parameter if params[1].value == 1: params[8].enabled = 1 # string parameter params[8].parameterType = "Optional"
- If at least the first boolean is true (box checked), the string (defined initially as disabled and optional) must be set to enabled and required.
- If only the second boolean is true, the string must remain disabled and optional.
