Push JSON to an External WebSocket Error ESRI Geoevent
Has anyone successfully configured a Push To An External Websocket with ESRI geoevent? I have an input a connector, service connector, and an output, however when I start the output I immediately get the error:
Status: Error - Could not startup the WebSocket Transport. An initialization problem has occurred. Error: Connection refused: no further information.
I increased the buffer and text bytes to 102400 in the settings and used the default output settings:ws://localhost:80/ws also tried ``wss://localhost:6180/ws2`
I am outputting a simulation stream to troubleshoot and I can output UDP so I know GeoEvent is working in some capacity.
I have tested this both on linux redhat 7.1 and windows 7 and the results are the same. I can attempt any suggestions provided on either OS. And I am running ArcGIS Server 10.3.1 on local machines.
