Publishing a service (A tale of two users)
So i have two users; arcgis_db and AD\raclark, one can publish a service the other can not.
It all goes fine till i get to the 'service editor' screen and click 'analyze'. One user, arcgis_db comes back clean and ready to go the other user AD\raclark gets the dread 00179 error 'layers data source must be registered' however the the database i am using is registered with my ArcGIS Server site.
When i look at the server logs i see this...
Server Log
"The connection property set was missing a required property or the property value was unrecognized. Underlying DBMS error[[Microsoft][ODBC Driver 11 for SQL Server][SQL Server]Login failed. The login is from an untrusted domain and cannot be used with Windows authentication.No extended error.]"
So i can not figure it out. one user can publish a service the other user can not and it stalls out when it comes to registering data with the server.
So what is about the users that is causing this?
arcgis_db is mapped to the 'public' and 'sysadmin' server roles; it is also mapped to the 'Facilities' database as 'db_owner'. So it is the dbo and and 'sysadmin'. its also SQL server authenticated login.
AD\raclark is a mapped to the 'public' server role; he is also mapped to the 'Faclities' database as 'public' and 'data_editor' role (data editor role is given SELECT, INSERT, UPDATE, DELETE privileges on each of the feature datasets / feature classes in the database). He is OS authenticated login.
Also...
SQL Server, Windows Server 2012R, drivers are current and correct, arcgis 10.3, arcgis server 10.3
