Problem Starting up Tile Server
I'm following the Switch2OSM guide to the tee. I have not had any trouble I couldn't figure out until now. I've typed the following according to instruction:
sudo mkdir /var/run/renderd
sudo chown username /var/run/renderd
sudo -u username renderd -f -c /usr/local/etc/renderd.conf
I get this error:
renderd[8641]: An error occurred while loading the map layer 'default': Could not create datasource for type: 'shape' encountered during parsing of layer 'land-low' in Layer at line 48 of '/usr/local/share/maps/style/OSMBright/OSMBright.xml'renderd[8641]: An error occurred while loading the map layer 'default': Could not create datasource for type: 'shape' encountered during parsing of layer 'land-low' in Layer at line 48 of '/usr/local/share/maps/style/OSMBright/OSMBright.xml'renderd[8641]: An error occurred while loading the map layer 'default': Could not create datasource for type: 'shape' encountered during parsing of layer 'land-low' in Layer at line 48 of '/usr/local/share/maps/style/OSMBright/OSMBright.xml'
