PostGIS - Merging linestrings into multilinestrings in a particular order
I have a set of linestrings, which I want to group into a single multilinestring, and in a specific order. However, when I use ST_Collect, it merges them out of order, like this:
Geometries as linestrings:
Order at which the multilinestring is being generated:
I know this "order" is only in my head really, and the function will use some parameter to determine the order. A quick research has given me that ST_Collect does its magic ordering by the row id, but for reasons I won't bother going through here I can't reorder my ids in the "aggregating order".
I do, however, have a separate table with the correct order, that's referencing the geom ids, so a simple join would suffice to put them in order, but ST_Collect is ignoring that. Is there a way to aggregate linestrings into a multilinestring using the ordering from this second table?
(the drawings are merely illustrative, but depict a real case, that is, some of the lines are not connected, and must remaind so. Therefore, I can't use ST_LineMerge to "force" a correct order out of it)
