Polygons will not buffer in ArcMap and instead give WARNING 000117: Warning empty out
I have been trying to buffer 15 polygons (-15m) in ArcMap. I did a batch buffer and 13 polygons worked fine, the other 2 have not buffered, an error occurs:WARNING 000117: Warning empty output generated.Executed (Buffer) successfully.End Time: Fri Jul 06 18:58:32 2012 (Elapsed Time: 1.00 seconds)
All the input polygons are similar with full attribute tables so the output should not be empty for these 2!
