have an issue with pgRouting that I've modified to consider multi-floor indoor areas. I've created a mock floor plan of any typical hotel. I copied the floor plan and assigned a different z-value to essentially mirror the floor plan, with one positioned directly above the other. I then made vertical connections between the floors for elevators and stairs to create a complete 3D network.
Using the SQL code found here https://github.com/mapcentia/geocloud2/blob/master/app/scripts/sql/pgr_createTopology3D.sql (thanks for that, BTW), I created the modified pgr_createTopology3d and pgr_pointToIdZ functions to build topology on the 3D network. Following that, I followed normal procedure for building the SQL View to serve the queried results as a layer to GeoServer
When constructing the SQL View, I used a modified version of pgr_fromAtoB to consider z-values. I modified as follows (thanks underdark):
-- Find nearest node EXECUTE 'SELECT id::integer FROM ways_vertices_pgr ORDER BY the_geom ST_GeometryFromText(''POINT(' || x1 || ' ' || y1 || ' ' || z1 || ')'',4326) LIMIT 1' INTO rec; source := rec.id; EXECUTE 'SELECT id::integer FROM ways_vertices_pgr ORDER BY the_geom ST_GeometryFromText(''POINT(' || x2 || ' ' || y2 || ' ' || z2 || ')'',4326) LIMIT 1' INTO rec; target := rec.id; However, it doesn't appear that the z-value is being considered. For example, I have nodes lying exactly on top of each other with the same lat/long, but with differing z-values. I can issue the ST_GeometryFromText command and limit the results to 2 and see the both of the nodes are being returned at the lat/long I've specified. However, the z-value for the bottom node is 0 and the upper node is 1. No matter what z-value I specify in the request, the upper node is always returned as the top result. Does anyone know why? How can I get it to return the bottom node if I specify the z-value as 0?
Thanks in advance for any insight.
