My map in Openlayers (Ol3) contains a WFS layer with GeoJSON format from Geoserver. My intention is to use CQL filters that can be applied by the user through comboboxes next to the map. The CQL filter works initially but I cannot get the layer to reload with the modified CQL once the url of the vector source changes. Perhaps this method (modifying the url of the vector source) is not even the correct way of doing it. The idea is almost the same as this tutorial on Geoserver: http://docs.geoserver.org/stable/en/user/tutorials/cql/cql_tutorial.html#cql-tutorial
After pressing the "Apply"-button in the tutorial, the layer adjusts to the new parameters. The tutorial however uses WMS and the method updateParams() to update the parameters which doesn't work for WFS. My question is: What is the proper method to update parameters on a WFS layer?
Some code:
var municipality = 'Lund';var vectorSource = new ol.source.Vector({url:"http://localhost:8081/geoserver/reporter/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=reporter:gtest&CQL_FILTER=name="+"'"+municipality+"'"+"&maxFeatures=50&outputFormat=application%2Fjson",format: new ol.format.GeoJSON(), });function reload() {municipality=document.getElementById("municipalityselector").value;}...DefaultLundHej
Some code:
