I'm currently working with Leaflet and a dockable web framework called Golden Layout. I'm trying to load tiles into the map, but they are not loading properly and I'm not sure why.
Currently, I have created a function to handle the creation of the map. The map container itself is created correctly, however when I try to add the tile layer, that's where things go wrong.
There are a couple problems with adding the tile layer. The first is that the tiles don't load except for the one in the top left hand corner. The second problem is what tile is being loaded. The tile that gets loaded in the top left hand corner is the tile I have set to be the center of my map.
If the page is adjusted in anyway (ex: console opened), all the tiles will load and the center will be correct.
I've created a Codepen to show the problem.
