I'm trying to convert between two coordinate systems using pyproj:
import pyprojp1 = pyproj.Proj("+init=EPSG:4326")p2 = pyproj.Proj("""PROJCS["NAD27 / California zone II",GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982138982]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_parallel_1",39.83333333333334],PARAMETER["standard_parallel_2",38.33333333333334],PARAMETER["latitude_of_origin",37.66666666666666],PARAMETER["central_meridian",-122],PARAMETER["false_easting",2000000],PARAMETER["false_northing",0],UNIT["Foot_US",0.30480060960121924]]""")p1 creates fine but p2 gives projection not found
I have corresponding points in both coordinate systems but transforming them using EPSG26742 doesnt give the correct result:
import pyprojp1 = pyproj.Proj("+init=EPSG:4326")p2 = pyproj.Proj("+init=EPSG:26742")a = (-121.330272, 38.547287, 5.661467)b = (2191840.924977, 321431.770306, 44.012074)print "Source point", aprint "Target point", bprint 'Converted: ', pyproj.transform(p1, p2, *a) # different
