How to change owner of versioned GDB version using ArcObjects?
I have ArcObjects/.NET code used to create few versions for workspace. Versions are created successfuly but their owner is who created them (the user connected to the workspace). I want to change the owners names, but I dont see an API to do that, maybe someone knows what interface I should use etc?
Everytime connecting as different user is not an option, because somehow unmanaged memory starts to leak when inserting/deleting/updating versioned data from many different connections.
Also I found table sde.VERSIONS it has column 'OWNER' but I am not sure if simply updating this column for specific versions is the correct solution, maybe it has some side effects.
