I need to try and automate the process of creating mask layers by using the symmetric difference of two different polygon layer files (they are currently in .TAB format, however these can be converted to .shp if need be) using OGR in Python.
The following is the code:
outputFileName = new+"mask.TAB"driver = ogr.GetDriverByName("MapInfo File")f1 = driver.Open(new+boundname,0)layer1 = f1.GetLayer(0)feature1 = layer1.GetNextFeature()if f1 is None: print "Could not open file ", f1 sys.exit(1)f2 = driver.Open(new+regionname,0)layer2 = f2.GetLayer(0)if f2 is None
rint "Could not open file ", f2### Create output file ###if os.path.exists(outputFileName): os.remove(outputFileName)try: output = driver.CreateDataSource(outputFileName)except: print 'Could not create output datasource ', outputFileName sys.exit(1)newLayer = output.CreateLayer('SymmetricDifference',geom_type=ogr.wkbPolygon,srs=layer1.GetSpatialRef())if newLayer is None: print "Could not create output layer" sys.exit(1)newLayerDef = newLayer.GetLayerDefn()featureID = 0while feature1: layer2.ResetReading() geom1 = feature1.GetGeometryRef() feature2 = layer2.GetNextFeature() while feature2: geom2 = feature2.GetGeometryRef() if geom1.Overlaps(geom2) == 1: newgeom = geom1.SymDifference(geom1,geom2) newFeature = ogr.Feature(newLayerDef) newFeature.SetGeometry(newgeom) newFeature.SetFID(featureID) newLayer.CreateFeature(newFeature) featureID += 1 newFeature.Destroy() else: newFeature1 = ogr.Feature(newLayerDef) newFeature1.SetGeometry(geom1) newFeature1.SetFID(featureID) newLayer.CreateFeature(newFeature1) featureID += 1 newFeature2 = ogr.Feature(newLayerDef) newFeature2.SetGeometry(geom2) newFeature2.SetFID(featureID) newLayer.CreateFeature(newFeature2) featureID += 1 newFeature1.Destroy() newFeature2.Destroy() feature2.Destroy() feature2 = layer2.GetNextFeature()feature1.Destroy()feature1 = layer1.GetNextFeature()f1.Destroy()f2.Destroy() From this, I get the following output:
However, what I actually want this script to do is create a hole in the larger polygon as shown below
Any ideas where I am going wrong in the code?
