How can i automate the join and export process using arcpy?
I want to compare two layers(for example layer A and B) with two fields using arcpy and export the records that are not in layer B but located in layer A. without arcpy i always join the layers and then select the records:
  1. join layer A with layer B
  2. select all records in layer A
  3. remove join
  4. switch selection
  5. export the selected records.
in the process i use join,select all,switch select and export selected records.But i don't know how can i use arcpy to export the records ? Is that any good solution to automate the process using arcpy? I want to use the code with stand alone script.Thanks.
