Higher resolution contours with Mapzen altitude tiles
We recently did several posts about drawing contours using altitude data from different Altitude API services. The first version used the Google Maps Elevation API and the second used Mapzen’s elevation API. The biggest problem was that the API’s are throttled, in Google’s case, to stop abuse and in Mapzen’s case due to limited server […]
The post Higher resolution contours with Mapzen altitude tiles appeared first on Google Earth Blog.
