My situation is that i'm trying to build a mobile app, and find the x number of points closest to a users location that satisfy certain conditions that the user choses on the front end. My current solution is to incrementally search a small area around the user and expand the search area until the x items are found or the maximum bounds are reached, using a JTS QuadTree.
public static Set searchQuadTree(Quadtree quadTree, final MyBoundary, data_bounds, final ArrayList types) { //used to search QuadTree double shell = SHELL; final double EXPAND_SHELL = 5000; final double MAX_SHELL_SIZE = 70000; final int MAX_SEARCH_ITEMS = 20; Set resultSet = new HashSet(); //create polygon to search for points that intersect with it Polygon polygon = data_bounds.searchAreaPoly(shell, 0); List items = quadTree.query(polygon.getEnvelopeInternal()); if(items != null) { GeometryFactory factory = new GeometryFactory(); //search until the min search items are found using search criteria while ((resultSet.size() < MAX_SEARCH_ITEMS) && (shell < MAX_SHELL_SIZE)) { Iterator iterator = items.iterator(); while (iterator.hasNext()) { MyQuadNode item = iterator.next(); Point point = factory.createPoint(getWGSCoord(item.getLongitude(), item.getLatitude())); if (types.contains(item.getType()) && polygon.contains(point) && resultSet.size() < MAX_SEARCH_ITEMS) { resultSet.add(item.getImageUrl()); } } } if(resultSet.size() < MAX_SEARCH_ITEMS) { //expand shell slowly at first; if (shell < 1000) { shell *= 5; } else if (shell < 5000) { shell *= 2; } else { shell += EXPAND_SHELL; } //search a larger area polygon = data_bounds.searchAreaPoly(shell, 0); List allItems = quadTree.query(polygon.getEnvelopeInternal()); //avoid filtering the same items twice allItems.removeAll(items); items = allItems; } } } return resultSet;}This will work fine for a small data set, if the data set grows large however this seems pretty inefficient, i'm estimating worst case is around n^2 log n (maybe n^3 if the tree is completely unbalanced), and I'm guessing this problem has probably been solved by someone smarter than me, so if anyone could point me in a better direction i'd appreciate it.
thanks
thanks
