gpspipe returns correct timestamp, but wrong date (21 dec 1995)
I'm having this strange issue where my gps pipe is returning the correct location and time but the wrong date (including year).
For reference, at the time of writing it is 06 aug 2015, 09:27 UTC).
I don't think it's a hardware issue, as on another device the GPS always returns the correct date/time. However, on one device most of the times it returns 21 Dec 1995, 09:20 UTC), so it gets the date wrong.
As you can see from the output below, it reports the year being 1995. The time is ok (09:20)
gpspipe -n 10 -r {"class":"VERSION","release":"3.4","rev":"3.4","proto_major":3,"proto_minor":6}{"class":"DEVICES","devices":[{"class":"DEVICE","path":"/dev/gps0","activated":"1970-01-01T00:00:20.040Z","flags":1,"driver":"SiRF binary","native":1,"bps":4800,"parity":"N","stopbits":1,"cycle":1.00}]}{"class":"WATCH","enable":true,"json":false,"nmea":true,"raw":0,"scaled":false,"timing":false}$GPGSV,3,1,09,06,18,040,32,12,49,079,30,24,17,144,35,02,34,078,27*73$GPGSV,3,2,09,14,32,240,29,29,51,202,24,31,34,306,18,25,82,339,00*7C$GPGSV,3,3,09,125,28,205,30*78$GPZDA,092014.00,21,12,1995,00,00*6C$GPGGA,092014,5101.2493,N,00428.9160,E,1,07,0.80,15.88,M,47.128,M,,*76$GPRMC,092014,A,5101.2493,N,00428.9160,E,0.0000,0.000,211295,,*26$GPGSA,A,3,29,12,02,31,14,06,24,,,,,,1.9,0.8,1.6*38A couple of reboots before this it returned this
gpspipe -n 10 -r {"class":"VERSION","release":"3.4","rev":"3.4","proto_major":3,"proto_minor":6}{"class":"DEVICES","devices":[{"class":"DEVICE","path":"/dev/gps0","activated":"2015-08-06T09:18:29.903Z","flags":1,"driver":"SiRF binary","native":1,"bps":4800,"parity":"N","stopbits":1,"cycle":1.00}]}{"class":"WATCH","enable":true,"json":false,"nmea":true,"raw":0,"scaled":false,"timing":false}$GPZDA,091834.00,06,08,2015,00,00*69$GPGGA,091834,5101.2482,N,00428.9175,E,1,07,1.20,20.04,M,47.128,M,,*72$GPRMC,091834,A,5101.2482,N,00428.9175,E,0.0000,0.000,060815,,*2D$GPGSA,A,3,25,29,12,02,14,06,24,,,,,,2.2,1.2,1.9*31$GPGBS,091834,13.04,M,13.57,M,42.74,M*0A$GPGSV,3,1,09,02,34,079,33,06,19,040,35,12,49,078,34,24,18,144,34*7A$GPGSV,3,2,09,25,82,336,24,14,33,240,26,29,50,202,20,31,33,306,02*72As you can see here the date is correct (06 Aug 2015).
On both machines the GPSD process is starting like this:
/usr/sbin/gpsd -bn -F /var/run/gpsd.sock -P /var/run/gpsd.pid /dev/gps0What could cause the GPS to think it's 1995 ? The Latitude/Longitude is always correct, so it is able to communicate properly with the satellites.
