GPS Analyst Extension
for
ESRI ArcGIS Desktop Software
Product Information
GPS Analyst Extension for ESRI ArcGIS Desktop Software P/N 52726-04
Streamlined GPS data processing inside ArcGIS
The Trimble® GPS Analyst™ extension for ESRI ArcGIS Desktop software will streamline your workflow and improve your productivity by enabling you to work directly with GPS data inside your personal geodatabase. Because GPS Analyst extension comes with Trimble's proven differential correction tools, you can be sure you have the best quality GPS data.
The GPS Analyst extension is the only software that allows you to differentially correct your GPS data directly inside ArcGIS Desktop software. Depending on the environment and your GPS receiver, differential correction can improve the accuracy of your GPS positions from 10 meters to submeter, and better. With Trimble's new H-Star™ technology you can achieve accuracies of subfoot (30 cm), 8 inches (20 cm) with the GeoXH™ 2005-series handheld and GPS Pathfinder® ProXH™ receiver, and 4 inches (10 cm) with the GeoXH 2008-series handheld and GPS Pathfinder ProXRT receiver.
Say goodbye to unnecessary file conversions�with GPS Analyst you can bring GPS data straight from the field into the geodatabase. GPS Analyst offers a seamless workflow for the ESRI ArcPad software with the Trimble GPScorrect™ extension for ESRI ArcPad software. Check data out; use, verify, and update the data in the field using ArcPad and the GPScorrect extension; and then check updated data back in. There are no extra steps or complicated procedures to follow. You can even work directly with data from the Trimble TerraSync™ software, for a proven data collection and maintenance solution.
The GPS Analyst extension is fully customizable with ArcObjects, giving you the flexibility to adapt it to your data processing needs. You can even take ArcGIS into the field on a laptop computer or Tablet PC, and capture data directly into the geodatabase. Or if you have your own field solution, write a plug-in that takes advantage of GPS Analyst's powerful data processing tools.
Let GPS Analyst extension improve your data accuracy and your field-to-office workflow by making GPS data an integral part of your GIS.
Key features:
View, edit, and analyze GPS data in ArcGIS
Improve productivity by eliminating extra file conversions and processing steps outside the GIS
Differentially correct for improved GPS position accuracy including Trimble H-Star processing for subfoot accuracy
Check data out to Shapefiles for update in the field with ArcPad and the GPScorrect extension, then check new and updated features and GPS positions back into the geodatabase
Import features and GPS positions from Trimble SSF files, including data collected with Trimble TerraSync software
Validate GPS positions to ensure features meet your accuracy requirements
Store detailed quality information for GPS data in the geodatabase
Use ArcGIS in the field to collect features and GPS data directly to the geodatabase
Use ESRI ArcObjects to customize workflows or data processing to suit your requirements
License Manager allows easy management of multiple licenses, including the choice of single-use or floating licenses
Notes:
GPS Analyst comes standard with 12 months enhancement eligibility
This software is for use with ESRI ArcGIS Desktop 9.0 SP3 or later.
Be the first to review this product!
The Trimble® GPS Analyst™ extension for Esri ArcGIS Desktop software will streamline your workflow and improve your productivity by enabling you to work directly with GNSS data inside your personal geodatabase. Because the extension comes with a package of powerful GNSS postprocessing tools, incorporating the new Trimble DeltaPhase™ differential correction technology, you can be sure you have GNSS data that is consistent, reliable, and accurate.
The GPS Analyst extension allows you to differentially correct your GNSS data directly inside Esri ArcGIS Desktop software. Postprocessing gives significant improvements on your autonomous accuracy all the way down to decimeter (10 cm / 4 inch) level, depending on the environment and your GNSS receiver. Using Trimble's H-Star™ technology you can achieve decimeter accuracy with the GPS Pathfinder® ProXH and ProXRT receivers and the GeoXH™ 6000 series handheld. With a GeoXT™ or a ProXT™ receiver GPS Analyst provides the option of standard carrier post-processing. Alternatively, with a Juno® series handheld or other code receiver, you can achieve optimal GNSS code processing accuracy with the Trimble DeltaPhase technology.
Say goodbye to unnecessary file conversions—with the GPS Analyst extension you can bring GNSS data straight from the field into the geodatabase. The GPS Analyst extension offers a seamless workflow for the Esri ArcPad software when combined with the Trimble GPScorrect™ extension for Esri ArcPad software. Check data out; use, verify, and update the data in the field using ArcPad and the GPScorrect extension; and then check updated data back in. There are no extra steps or complicated procedures to follow. You can even work directly with data from the Trimble TerraSync™ software, for an alternative data collection and maintenance solution.
The GPS Analyst extension is fully customizable with Esri ArcObjects, giving you the flexibility to adapt it to your data processing needs. You can even take ArcGIS into the field on a laptop computer or Tablet PC, and capture data directly into the geodatabase. If you have your own field solution, write a plug-in that takes advantage of the GPS Analyst extension's powerful data processing tools.
Let the GPS Analyst extension improve your data accuracy and your field-to-office workflow by making GNSS data an integral part of your GIS.
Key features:
Collect, view, and edit GNSS data inside Esri ArcGIS Desktop software versions 9.x and 10
Improve GNSS position accuracy with differential correction of data from supported Trimble GNSS receivers including Trimble H-Star and DeltaPhase data postprocessing
Supports GLONASS post-processing for data collected with a GLONASS option-enabled GPS Pathfinder ProXRT receiver
Check data out to Shapefiles for update in the field with Esri ArcPad and the GPScorrect extension, then check new and updated features and GNSS positions back into the geodatabase
Import features and GNSS positions from Trimble SSF files, including data collected with the Trimble TerraSync software
Validate GNSS positions to ensure features meet your accuracy requirements
Store detailed quality information for GNSS data in the geodatabase
Use Esri ArcGIS in the field to collect features and GNSS data directly to the geodatabase
Use Esri ArcObjects to customize workflows or data processing to suit your requirements
License Manager allows easy management of multiple licenses, including the choice of single-use or floating licenses.
