I downloaded the latest stable release (2.7.1.1) from http://sourceforge.net/projects/geoserver/files/GeoServer/. It starts with the integrated jetty and works fine so far.
So I wanted to configure netCDF output for WCS Layers and downloaded the netCDF plugins from here: http://ares.opengeo.org/geoserver/2.7.x/community-latest/
However starting the server after installing them to geoserver/libs results in:
java.util.ServiceConfigurationError: javax.imageio.spi.ImageReaderSpi: Provider org.geotools.imageio.netcdf.NetCDFImageReaderSpi could not be instantiated at java.util.ServiceLoader.fail(ServiceLoader.java:232) at java.util.ServiceLoader.access$100(ServiceLoader.java:185) at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:384) at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404) at java.util.ServiceLoader$1.next(ServiceLoader.java:480) at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210) at javax.imageio.spi.IIORegistry.(IIORegistry.java:138) at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159) at javax.imageio.ImageIO.(ImageIO.java:66) at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:121) at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540) at org.mortbay.jetty.servlet.Context.startContext(Context.java:135) at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220) at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510) at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448) at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39) at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152) at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156) at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39) at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152) at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39) at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130) at org.mortbay.jetty.Server.doStart(Server.java:222) at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39) at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.mortbay.start.Main.invokeMain(Main.java:183) at org.mortbay.start.Main.start(Main.java:497) at org.mortbay.start.Main.main(Main.java:115)Caused by: java.lang.NoClassDefFoundError: org/geotools/coverage/grid/io/FileSetManager at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:760) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142) at java.net.URLClassLoader.defineClass(URLClassLoader.java:467) at java.net.URLClassLoader.access$100(URLClassLoader.java:73) at java.net.URLClassLoader$1.run(URLClassLoader.java:368) at java.net.URLClassLoader$1.run(URLClassLoader.java:362) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:361) at java.lang.ClassLoader.loadClass(ClassLoader.java:424) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:760) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142) at java.net.URLClassLoader.defineClass(URLClassLoader.java:467) at java.net.URLClassLoader.access$100(URLClassLoader.java:73) at java.net.URLClassLoader$1.run(URLClassLoader.java:368) at java.net.URLClassLoader$1.run(URLClassLoader.java:362) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:361) at java.lang.ClassLoader.loadClass(ClassLoader.java:424) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at java.lang.Class.getDeclaredConstructors0(Native Method) at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671) at java.lang.Class.getConstructor0(Class.java:3075) at java.lang.Class.newInstance(Class.java:412) at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:380) ... 29 moreCaused by: java.lang.ClassNotFoundException: org.geotools.coverage.grid.io.FileSetManager at java.net.URLClassLoader.findClass(URLClassLoader.java:381) at java.lang.ClassLoader.loadClass(ClassLoader.java:424) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ... 56 more
