I have a shapefile with N columns describing different attributes of some features. I would like to generate a grid of maps, where each map is a different column. Visually, I'm thinking of something like this:
I can easily generate a single map manually with QGIS, but I would like to automate the process to be able to generate hundreds of such maps very quickly.
I started to code a PyQGIS script following this recipe, but I keep getting segmentation faults (I'm on MacOS X, QGIS Wien).
What would you recommend? I thought of using R, but the output tends to be visually less appealing than QGIS.
