Esri API JS, popup not displaying after first click
Demographics data shows upon first click but not after, park information does work. I've changed around almost everything with non real solution. I feel like for whatever reason my feature server data is preferred over the dynamiclayer in the map. Is there a way to make the js bounce based on where you click?
var map; require([ "esri/config", "esri/InfoTemplate", "esri/map", "esri/dijit/Popup", "esri/dijit/PopupTemplate", "esri/geometry/Extent", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "esri/layers/ArcGISTiledMapServiceLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/GeometryService", "esri/tasks/query", "dojo/dom-construct", "dojo/dom-class", "dojo/parser", "esri/Color", "dojo/_base/lang", "dojo/date/locale", "esri/dijit/Geocoder", "esri/dijit/LocateButton", "dojo/domReady!" ], function ( esriConfig, InfoTemplate, Map, Popup, PopupTemplate, Extent, ArcGISDynamicMapServiceLayer, FeatureLayer, ArcGISTiledMapServiceLayer, SimpleFillSymbol, SimpleLineSymbol, GeometryService, Query, domConstruct, domClass, parser, Color, lang, locale, Geocoder, LocateButton ) { parser.parse(); var popup = new Popup({ fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 2), new Color([128, 128, 128, 0.25])) }, domConstruct.create("div")); domClass.add(popup.domNode, "myTheme"); map = new Map("map", { basemap: "topo", center: [-122.402, 47], zoom: 9, infoWindow: popup }); var geocoder = new Geocoder({ arcgisGeocoder: { placeholder: "Search " }, map: map }, "ui-esri-dijit-geocoder"); var _countyCensusInfoTemplate = new InfoTemplate(); _countyCensusInfoTemplate.setTitle("Census Information"); var _blockGroupInfoTemplate = new InfoTemplate(); _blockGroupInfoTemplate.setTitle("Census Information"); var _censusInfoContent = "" + "${AGE_5_17:formatNumber}
people ages 5 - 17
" + "${AGE_18_21:formatNumber}
people ages 18 - 21
" + "${AGE_22_29:formatNumber}
people ages 22 - 29
" + "${AGE_30_39:formatNumber}
people ages 30 - 39
" + "${AGE_40_49:formatNumber}
people ages 40 - 49
" + "${AGE_50_64:formatNumber}
people ages 50 - 64
" + "${AGE_65_UP:formatNumber}
people ages 65 and older" + "
"; _countyCensusInfoTemplate.setContent("Demographics for:
${NAME} ${STATE_NAME:getCounty}, ${STATE_NAME}
" + _censusInfoContent); _blockGroupInfoTemplate.setContent("Demographics for:
Tract: ${TRACT:formatNumber} Blockgroup: ${BLKGRP}
" + _censusInfoContent); var demographicsLayerURL = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer"; var demographicsLayerOptions = { "id": "demographicsLayer", "opacity": 0.8, "showAttribution": false }; var demographicsLayer = new ArcGISDynamicMapServiceLayer(demographicsLayerURL, demographicsLayerOptions); demographicsLayer.setInfoTemplates({ 1: { infoTemplate: _blockGroupInfoTemplate }, 2: { infoTemplate: _countyCensusInfoTemplate } }); demographicsLayer.setVisibleLayers([1, 2]); map.addLayer(demographicsLayer); geocoder.startup(); var geoLocate = new LocateButton({ map: map, highlightLocation: false }, "LocateButton" ); geoLocate.startup(); var formatNumber = function(value, key, data) { var searchText = "" + value; var formattedString = searchText.replace(/(\d)(?=(\d\d\d)+(?!\d))/gm, "$1,"); return formattedString; }; var getCounty = function(value, key, data) { if (value.toUpperCase() !== "LOUISIANA") { return "County"; } else { return "Parish"; } }; map.on("click", function (event) { var query = new Query(); query.geometry = pointToExtent(map, event.mapPoint, 10); var deferred = featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(event.mapPoint); }); var template = new InfoTemplate(); template.setTitle("Park Information"); template.setContent(getTextContent); var featureLayer = new FeatureLayer("https://services3.arcgis.com/J1Locv0GPOt6yBRR/ArcGIS/rest/services/Parks_polygons_Feb2012/FeatureServer/0", { outFields: ["*"], infoTemplate: template }); map.addLayer(featureLayer); function getTextContent (graphic) { var attributes = graphic.attributes; var namepark = attributes.ParkName .replace('"', "") .split("::") .map(function (name) { return lang.trim(name); }); var parkdata = namepark[0]; var commonName = namepark[1]; var parks; if (commonName) { parks = "" + commonName + "
" + "" + parkdata + ""; } else { parks = "" + parkdata + ""; } return parks + "
" + attributes.Owner + "
" + attributes.ParkWebLin } function pointToExtent (map, point, toleranceInPixel) { var pixelWidth = map.extent.getWidth() / map.width; var toleranceInMapCoords = toleranceInPixel * pixelWidth; return new Extent(point.x - toleranceInMapCoords, point.y - toleranceInMapCoords, point.x + toleranceInMapCoords, point.y + toleranceInMapCoords, map.spatialReference); } });
link to is http://students.washington.edu/sbuffor/combined_census_parks.html
