Trying to follow the Map Style tutorial, as the functionality of changing color of objects selected is one thing I am trying to add to my project. However, after running the code from the tutorial I get the following error:
Tutorial: http://docs.geotools.org/latest/userguide/tutorial/map/style.html
Note: My code and pom.xml is exactly as shown in the tutorial (I had to tweak a few things, also I am using 14-SNAPSHOT).
Error:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException at org.geotools.data.shapefile.ShapefileFeatureSource.getReaderInternal(ShapefileFeatureSource.java:336) at org.geotools.data.shapefile.ShapefileFeatureStore.getReaderInternal(ShapefileFeatureStore.java:126) at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:634) at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:173) at com.mycompany.mapselection.App.selectFeatures(App.java:167) at com.mycompany.mapselection.App$1$1.onMouseClicked(App.java:132) at org.geotools.swing.event.DefaultMapMouseEventDispatcher.mouseClicked(DefaultMapMouseEventDispatcher.java:99) at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:270) at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:269) at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:269) at java.awt.Component.processMouseEvent(Component.java:6519) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Error:
