Debugging AttributeError: Object: Tool or environment not found in arcgisscripting?
I have a problem executing the code below in ArcGIS 9.3. The file is not found in split_row_0717.py Please kindly help any modification and thank you.
The error said that
Traceback (most recent call last): File "C:\Python25\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 310, in RunScript exec codeObject in main.dict File "H:\python_p\python_code\split_row_0717.py", line 46, in gp.SplitByAttribute_Analysis2(fc, fieldName, outWorkspace, fieldName) AttributeError: Object: Tool or environment not found
##Script Name: split rows ##Description: using ##Created By: Elaine Kuo ##Date: 12/07/2012 #Import standard library modules import arcgisscripting import os #Create the Geoprocessor object gp = arcgisscripting.create(9.3) #Set the workspace. gp.Workspace= "H:/temp/test" #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp" # Add a toolbox with a model to the geoprocessor and set the workspace gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolBox/Toolboxes/AdditionalAnalysis/Additional Analysis - Generic Tools.tbx") #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses() # Loop through every item in the list that was just generated for fc in fcs: # Break out the name, no path or extension, using the describe object. desc = gp.describe(fc) featureName = desc.name # Validate the new feature class name for the output workspace. OutFeatureClass = outWorkspace + os.sep + gp.ValidateTableName(fc,outWorkspace) #get file name fcName, fcExt = os.path.splitext(fc) #build field name fieldName = fcName #### Execute Script Tool #### gp.SplitByAttribute_Analysis2(fc, fieldName, outWorkspace, fieldName) gp.AddMessage(gp.GetMessages()) print gp.GetMessages()
