Using QGIS, I started with LIDAR points (every 5 m) on a 90’000 ha area and then converted it in a raster of elevation (interpolating to fill some holes in LIDAR data). Now, I want to get a polygon representing the surface for which the cell value is equal or below a given threshold value.
I tried two methods:
A) Creating contours at the threshold value from the raster and converting these contours to polygons.B) Polygonizing the raster reclassified as zeros (cell > x) and ones (cell =< x) and then simplifying it to a more contour-like shape.
Using method A, the result is really close to what I want. Polygons are created but polygons that should be holes within a polygon, or islands within a hole, are created as separate polygons. Is there a way to convert contour lines into polygons while keeping holes and islands? If not, is there a way to correct this afterwards?
Method B seems a good approach in theory although very time consuming (in processing time). I found instructions proposed previously by « Lars » using GRASS (GRASS v.generalize method=Douglas not working as expected). I’m satisfied with the result I got using a sampled polygon, but it doesn’t seem to work when using complete dataset : the processing of « v.generalize » seems to either crash or stop, and it happens when topology is building. I wonder if it’s only a matter of file size and computing limitations or if it’s a little more complicated than that.
v.generalize -c input=Vectorised_RASTER@username output= generalized_RASTER method=douglas threshold=5
