I have a question concerning creating the largest possible circle inside a polygon including its perimeter and area size. I created via minimum boundary geometry the smallest possible circle outside a polygon (see image) and want to do some calculation with its largest circle inside the polygon. I have a shapefile of 25 polygons. Each has to have its own largest circle. This circle can be anywhere in the polygon, not necesserily at the centre since my polygons are uneven.
I tried looking at Find maximum radius of circle that will fit within an irregular polygon? but it was no succes. I have the same problem as the OP.
