Create a geoserver SQL view from Oracle SQL using a lat and lng column
I have a table in a Oracle SQL database in which I have a polygon geometry and two more columns of latitude and longitude. What I need is to show the points of lat and lng in a layer in geoserver.
I have done similar thing using PostGIS but in now with Oracle I face an error.First I have create a query which selects the two coloumns, transforms them to the desired SRID (EPSG:2100), REPLACE the '.' with the ',' and CAST them to float (cause they are characters).
When I execute the query in the Oracle SQL developer it seems that it works correctly. Also if I copy and paste teh coords they are shown in the correct position on the map.
But when I se my query in geoserver in order to create a sql view layer, although the geometry column is recognized (also the SRID), when I click on the "compute BBOX" option I get a geoserver error.
As I said I did something similar with postGIS and it was working fine. I also tried to use the same table (but its existing geometry; the polygon) and it works also great.
So I guess it must be related with my query but I can not guess what can cause this "unexpected geoserver error".
Thats my query:
SELECT ID, CO_NAME, ADJUSTMENT_FACTOR, PORT_LOCATION, VDSL_ENABLED,SDO_CS.TRANSFORM(SDO_GEOMETRY(2100,4326,SDO_POINT_TYPE(CAST(REPLACE(CENTRAL_OFFICES.LAT, '.', ',') AS FLOAT), CAST(REPLACE(CENTRAL_OFFICES.LNG, '.', ',') AS FLOAT),NULL),NULL,NULL),2100) AS geomFROM CENTRAL_OFFICES
