converting shp to fileGDB with ogr2ogr changes geometry type?
I'm converting a shapefile to file geodatabase with GDAL 1.11.3 and the ESRI FileGDB driver.
ogrinfo on the .shp gives:
$ ogrinfo NED1_Index.shpINFO: Open of `NED1_Index.shp' using driver `ESRI Shapefile' successful.1: NED1_Index (Polygon)I run this command:
$ ogr2ogr -f "FileGDB" nedtest.gdb NED1_Index.shpor this one specifying the geometry type:
$ ogr2ogr -f "FileGDB" -nlt POLYGON nedtest.gdb NED1_Index.shpand then ogrinfo on the output fileGDB gives:
$ ogrinfo nedtest.gdb/ INFO: Open of `nedtest.gdb/' using driver `FileGDB' successful. 1: NED1_Index (Multi Polygon)Why is the geometry changing to MultiPolygon?
