I am trying to get a number by counting how many points are in a shapefile. And this works (I think), except I then am running into trouble using that number somewhere else. Eventually, I'll be using that count in some math (field calculator), but while debugging I'm running into an error that will end up causing me trouble later on. This code:
TotalPoints = arcpy.GetCount_management(Path_Pts)arcpy.AddMessage(">>>> PROCESS: COUNT PATH POINTS {" + TotalPoints + "}")gives this error:
TypeError: cannot concatenate 'str' and 'Result' objectsI tried casting it as a int, which it ALSO doesn't like:
TypeError: int() argument must be a string or a number, not 'Result'So I've got a 'Result' object and need to turn it into a number. How can I do that -- or is using the arcpy function unnecessary or overly complicated here? (I'm learning arcpy and python as I go.)
