I have a geojson with a multipolygon and I want to fit this multipolygon to the map. The map center only on one polygon not on the multipolygon.
Here is my script
var map = L.map('map',{ zoomControl:false }) .setView([, ], 12); var zoomFS = new L.Control.ZoomFS(); map.addControl(zoomFS); var defaultLayer = new L.TileLayer.MapBox.Light({minZoom: 10, maxZoom: 16}); map.addLayer(defaultLayer); var info = L.control(); info.onAdd = function (map) { this._div = L.DomUtil.create('div', 'info'); this.update(); return this._div; }; info.update = function (props) { this._div.innerHTML = 'Massifs forestiers près de
' + (props ? '' + props.LLIB_FRT +'
' : 'Survolez une zone colorée'); }; info.addTo(map); // get color depending on population density value function getColor(d) { return d == 'OUI' ? '#238B45' : d == 'NON' ? '#74C476' : ''; } function style(feature) { return { weight: 1, opacity: 1, color: 'white', dashArray: '', fillOpacity: 0.7, fillColor: getColor(feature.properties.CDOM_FRT) }; } function highlightFeature(e) { var layer = e.target; layer.setStyle({ weight: 3, color: '#666', dashArray: '', fillOpacity: 0.7, fillColor: '#C7E9C0' }); if (!L.Browser.ie && !L.Browser.opera) { layer.bringToFront(); } info.update(layer.feature.properties); } var geojson; function resetHighlight(e) { geojson.resetStyle(e.target); info.update(); } function zoomToFeature(e) { map.fitBounds(e.target.getBounds()); } function onEachFeature(feature, layer) { layer.on({ mouseover: highlightFeature, mouseout: resetHighlight, click: zoomToFeature }); } geojson = L.geoJson(foret, { style: style, onEachFeature: onEachFeature }).addTo(map); map.fitBounds(map.getBounds()); var legend = L.control({position: 'bottomright'}); legend.onAdd = function (map) { var div = L.DomUtil.create('div', 'info legend'), grades = ['OUI','NON'], labels = [], from, to; labels.push( ' Forêt domaniale
' + ' Autre forêt' ); div.innerHTML = labels.join('
Source ONF'; return div; }; legend.addTo(map); And My Geojson call before the script :
var foret = {"type": "FeatureCollection","features": [{ "type": "Feature","id":"28", "properties": { "LLIB_FRT":"Forêt communale d'Hinsingen", "CDOM_FRT":"NON"}, "geometry": { "type": "MultiPolygon", "coordinates": [ [ [ [ 6.9943980558132, 48.946433094078 ], [ 6.994620292006, 48.946654797086 ], [ 6.9946440493621, 48.946769064939 ], [ 6.9942757111879, 48.947051596133 ], [ 6.994525224939, 48.947130121777 ], [ 6.9949682000749, 48.946963549201 ], [ 6.9953766392947, 48.947023616958 ], [ 6.9957374325074, 48.946813022271 ], [ 6.9965129612099, 48.946224218666 ], [ 6.9961325523574, 48.945968748319 ], [ 6.9957770974676, 48.945782611345 ], [ 6.9957646870665, 48.945668975401 ], [ 6.9959606190443, 48.945511036547 ], [ 6.9946195521361, 48.94466102012 ], [ 6.994630665892, 48.944546885841 ], [ 6.9947706431545, 48.944451927805 ], [ 6.9943890358713, 48.943557180488 ], [ 6.9939647083228, 48.942850378597 ], [ 6.9936098649794, 48.943031218817 ], [ 6.990978273955, 48.944169736953 ], [ 6.9907916915416, 48.944275487598 ], [ 6.9906590303195, 48.944540260439 ], [ 6.9903122282768, 48.945515871105 ], [ 6.9899779107984, 48.945891734939 ], [ 6.9897536964784, 48.946062513595 ], [ 6.9906082903887, 48.946007229028 ], [ 6.9907530326376, 48.946038714842 ], [ 6.9908245833021, 48.94612737104 ], [ 6.9909366304299, 48.946984068611 ], [ 6.9928842027716, 48.947039217107 ], [ 6.9929248400957, 48.946763159392 ], [ 6.9930024317067, 48.946669408079 ], [ 6.9931592044754, 48.946642240938 ], [ 6.9939125945186, 48.946695983544 ], [ 6.9940803721788, 48.946467213889 ], [ 6.9942616812201, 48.946401938807 ], [ 6.9943980558132, 48.946433094078 ] ],[ [ 7.0132518064932, 48.954701866676 ], [ 7.0130792746756, 48.955281720291 ], [ 7.0131097085661, 48.955406738419 ], [ 7.0134535050459, 48.956019942767 ], [ 7.0136768179147, 48.956641121897 ], [ 7.0136432241135, 48.956891471012 ], [ 7.013391660559, 48.95756050072 ], [ 7.0164377304443, 48.958126765886 ], [ 7.0173343130064, 48.958220743678 ], [ 7.0180405329659, 48.958235207654 ], [ 7.0180712371346, 48.957763530194 ], [ 7.018466890148, 48.957337559452 ], [ 7.0183245760167, 48.957321560691 ], [ 7.0182167345232, 48.957234693134 ], [ 7.0176940753708, 48.955926500229 ], [ 7.0171570061764, 48.955918750115 ], [ 7.0170252455885, 48.955885108994 ], [ 7.0165780794306, 48.955358357152 ], [ 7.016549105281, 48.955117411187 ], [ 7.0159152497559, 48.95481071823 ], [ 7.0155138192773, 48.954679378104 ], [ 7.015287839558, 48.954917146081 ], [ 7.015151253069, 48.954947663459 ], [ 7.0142533774551, 48.954711047176 ], [ 7.012862311613, 48.954409014242 ], [ 7.013130198481, 48.95455616266 ], [ 7.0132518064932, 48.954701866676 ] ] ] ] } }]}; Thanks for your help!
Here is my script
