حصري ArcGIS 10 (Desktop, Engine, Server) Service Pack 2 - English
حصري ArcGIS 10 (Desktop, Engine, Server) Service Pack 2 - English​
Installing this Service Pack on Windows
Installation Notes
ArcGIS 10 must be installed before you can install Service Pack 2. Service Pack 2 is cumulative and contains the fixes from all previous 10 patches. If you have a previous patch/service pack installed, you may apply Service Pack 2 over it to update the required files.
To Install:
Make sure you have write access to your ArcGIS installation location, and that no one is accessing it.
Select the appropriate files:
ArcGIS Desktop (ArcInfo, ArcEditor, ArcView, ArcGIS Eval Edition)
ArcGISDesktop10sp2.msp
364 MB
ArcGIS License Manager
ArcGISLicenseManager10sp2.msp
13 MB
ArcObjects SDK for the Microsoft .NET Framework
ArcObjectsSDKNET10sp2.msp
264 MB
ArcObjects SDK for Cross Platform C++
ArcObjectsSDKCPP10sp1.msp No Change Since 10 Service Pack 1
131 MB
ArcObjects SDK for the Java Platform
ArcObjectsSDKJava10sp2.msp
59 KB
ArcReader
ArcReader10sp2.msp
76 MB
ArcGIS Engine Runtime
ArcGISEngine10sp2.msp
138 MB
ArcGIS Server for the Java Platform
ArcGISServerJava10sp2.msp
146 MB
ArcGIS Server for the .Net Framework
ArcGIS Server - GIS Services
ArcGISServerGISServices10sp2.msp
118 MB
ArcGIS Server - Web Applications
ArcGISServerWebApplications10sp2.msp
54 MB
ArcGIS Server Web ADF Runtime
ArcGISServerWebADFRuntime10sp2.msp
50 MB
(Server for .Net Installation Only) From your Services control panel, stop the ArcGIS Server Object Manager and ArcGIS SOC Monitor.
(Server for Java Installation Only) From your Services control panel, stop the ArcGIS Server Manager Service, ArcGIS Server Object Manager and ArcGIS SOC Monitor.
(License Manager Only) From the Start/Stop License Service panel of the License Server Administrator, select 'Stop' and close the License Server Administrator.
Double-click the msp files to start the install process.
NOTE: If double clicking on the MSP file does not start the Service Pack 2 installation, you can start the Service Pack 2 installation manually by using the following command:
msiexec.exe /p [location of update]\<Product>10sp2.msp
When Setup starts, follow the instructions on your screen.
Repeat steps 2 - 6 for each product installed on your machine.
(License Manager Only) From the Start/Stop License Service panel of the License Server Administrator, select ‘Start’ and close the License Server Administrator.
required files.
