Stephen Mather: PostgreSQL table drop — a little fun with ouroboros
My latests posts on PDAL*have been fun. For the moment, a quick bit of code for dropping all the tables in your PostgreSQL database. BTW, the following is a bad idea. Many bad ideas are really useful. This is a really useful but bad idea:
echo "\dt" | psql | grep layer | awk '{print "DROP TABLE \"" $3"\";"}' | psqlHow does this work? Let’s do a quick step through.
First we echo “\dt”.
$ echo "\dt"\dtThis just prints literally (the literally kind of literally) “\dt”. \dt is a psql command for listing all the tables in your database. We “pipe” (this symbol is a pipe: |) that into psql. Essentially what this does is run this command within psql as follows:
$ echo "\dt" | psql List of relations Schema | Name | Type | Owner --------+--------------------+-------+--------- public | layer_0-1.5 | table | user public | layer_1.5-3 | table | user public | layer_105-150 | table | user public | layer_15-30 | table | user public | layer_150-200 | table | user public | layer_3-6 | table | user public | layer_30-45 | table | user public | layer_45-60 | table | user public | layer_6-15 | table | user public | layer_60-105 | table | user public | paw_points | table | user public | pointcloud_formats | table | user public | spatial_ref_sys | table | user(13 rows)Now that we have a list of tables, we can manipulate that list in order to manipulate our tables. We’ll use the grep command to go line by line and only return the ones with the word “layer” in them. These are the table names that we are interested in dropping.
$ echo "\dt" | psql | grep layer public | layer_0-1.5 | table | user public | layer_1.5-3 | table | user public | layer_105-150 | table | user public | layer_15-30 | table | user public | layer_150-200 | table | user public | layer_3-6 | table | user public | layer_30-45 | table | user public | layer_45-60 | table | user public | layer_6-15 | table | user public | layer_60-105 | table | userNow we use the awk command to just grab the column we want. By default, awk assumes spaces are our column delimiter, so we’ll grab the third column, however we could also use the pipes as our delimiter with the -F flag:
$ echo "\dt" | psql | grep layer | awk '{print $3}'layer_0-1.5layer_1.5-3layer_105-150layer_15-30layer_150-200layer_3-6layer_30-45layer_45-60layer_6-15layer_60-105Let us next extend the awk command to print the commands we want to run against our database. Note I had to escape my double quotes with a “\”:
$ echo "\dt" | psql | grep layer | awk '{print "DROP TABLE \"" $3"\";"}' DROP TABLE "layer_0-1.5";DROP TABLE "layer_1.5-3";DROP TABLE "layer_105-150";DROP TABLE "layer_15-30";DROP TABLE "layer_150-200";DROP TABLE "layer_3-6";DROP TABLE "layer_30-45";DROP TABLE "layer_45-60";DROP TABLE "layer_6-15";DROP TABLE "layer_60-105";Now we have the commands we need to feed back into psql to run against the database. Here is where the dragon eats its own tail:
echo "\dt" | psql | grep layer | awk '{print "DROP TABLE \"" $3"\";"}' | psqlDROP TABLEDROP TABLEDROP TABLEDROP TABLEDROP TABLEDROP TABLEDROP TABLEDROP TABLEDROP TABLEDROP TABLE
