In honor of the Esri Developers Summit going on right now in Palm Springs, California, I thought that I’d provide a quick look at a hidden capability in ArcGIS Earth 1.0 that allows a developer to enable end users to access additional information about a location.
In doing some experimentation, I found that I could add a call to What3Words*so that I can get the unique three word location for any spot on the planet.
What3Words embedded in ArcGIS Earth
We’ve had many users ask us for Google-like street view capability. While we don’t have that right now, I can demonstrated that I can call Google StreetView from inside ArcGIS Earth.
Google Street view with a Trimble 3D Warehouse model in the background in ArcGIS Earth
In the same way, I could be able to call a Mapillary or HERE service as well. *In experimenting with this, I found some limitations to the Earth embedded browser that I need to further investigate, especially when calling apps with JavaScript.
What3Words doesn’t export KML. Neither do the new Google StreetView APIs. *So how did this happen? It does require a little black magic.
These are the steps that I followed:
' + \ '' + \ data['words'][0] + ':' + \ data['words'][1] + ':' + \ data['words'][2] + \ '
' description2 = '' #Load and modify the KML template kmlFile = open('home/templates/response.kml', 'r') result = kmlFile.read() result = result.replace("%lon%", str(lon)). replace("%lat%", str(lat)). replace("%elevation%", str(elv)). replace("%description1%", description1). replace("%description2%", description2). replace("%title%", "What3Words Test") return result
What3Words in Rome
You could conceivably call any URL that can accept coordinates and which could return KML. If you launch a web page you could, for example, call other services or data links that could add data into your workspace.
Here are a few tips:
See you around the #DevSummit!
Note: If you haven’t downloaded ArcGIS Earth, yet, get it here!
If you take a look at the Administer web pages in the ArcGIS Earth documentation, you can see an innocuous entry called ServiceURL that can be configured in the ArcGISEarth.exe.config file that is in the Earth install directory. *The secret to this parameter is that it allows an administrator to enter a URL with some encoded values that will be recognized by Earth and filled with location information. *When a user then uses CTRL-RIGHT-CLICK on the globe, the URL will be invoked and the latitude, longitude, and elevation of the point clicked will be passed to that URL. *As long as the URL returns valid KML, the KML will be displayed in the Earth viewport.In doing some experimentation, I found that I could add a call to What3Words*so that I can get the unique three word location for any spot on the planet.
What3Words embedded in ArcGIS EarthWe’ve had many users ask us for Google-like street view capability. While we don’t have that right now, I can demonstrated that I can call Google StreetView from inside ArcGIS Earth.
Google Street view with a Trimble 3D Warehouse model in the background in ArcGIS EarthIn the same way, I could be able to call a Mapillary or HERE service as well. *In experimenting with this, I found some limitations to the Earth embedded browser that I need to further investigate, especially when calling apps with JavaScript.
- 1. Set up a simple CherryPy server
- 2. Created a simple KML template file that I could call repeatedly and placed it somewhere that I can load it in python
- 3. Created cherrypy app with a method that would represent my call from Earth that would be used to invoke the desired service. *In the case of What3Words, this was a simple method that builds some HTML around the What3Words request and embeds it in a basic KML placemark. *The pseudocode method looks like this:
- 4. Modified the ArcGISEarth.exe.config file to format the URL call. Here’s the example for my call to the What3Words CherryPy command:
- 5. Restart Earth, zoom in somewhere, and CTRL-RIGHT-CLICK… and this is what I see:
What3Words in RomeYou could conceivably call any URL that can accept coordinates and which could return KML. If you launch a web page you could, for example, call other services or data links that could add data into your workspace.
- Use the*urlwithpos*value for the key attribute on the add element under the ServiceURL element to enable this feature
- When formatting the URL in the config file, ampersand needs to be represented as*&
- %LONGITUDE% – Key value that represents the longitude of the point clicked
- %LATITUDE%*- Key value that represents the latitude of the point clicked
- %ELEVATION% – Key value that represents the elevation of the point clicked, currently in meters
- %HEADING% – At the ArcGIS Earth 1.1*release, we will be adding a value to represent the heading that the map view is currently facing
