HP Designjet 4520 HD-MFP - MULTIFUNCTION PLOTTERS
Ideal For :
Unattended printing of high-quality large-format drawings graphics, maps, presentations, renders, and posters
Primary application : Line drawings; Renderings; Presentations; Maps; Orthophotos Secondary Applications:Office Graphics; Newspaper
High quality, real productivity, and cost control features are yours with your HP Designjet. Large input and output capacity enables unattended printing. Control costs with more efficient use and management and greater visibility into expenses
Specifications
Model size
42 in
Functions
All-in-one functions
Print; copy; scan
Print Speed
Mechanical print time, US D color image, Normal mode, glossy
3.9 min/page
Mechanical print time, US D color image, Draft mode, coated
1.2 min/page
Mechanical print time, US D color image, Normal mode, coated
3.3 min/page
Mechanical print time, US D color line drawing, Draft mode, plain
25 sec/page
US D color line drawings/hr, Draft mode, plain
100 D prints per hour
Mechanical print time, US D b&w line drawing, Draft mode, plain
25 sec/page
Memory
Memory, standard
Printer: 608 MB; scanner: 1 GB
Hard disk
Printer: standard, 160 GB; scanner: standard, 40 GB
Printing
Print technology
HP Thermal Inkjet
Resolution technology
Color layering technology
Ink types
Dye-based (C, M, Y); pigment-based (K)
Ink cartridges
4 (1 each black, cyan, magenta, yellow)
Maximum roll length
575 ft
Line accuracy
+/- 0.1%
Connectivity, standard
Printer: 1 Gigabit Ethernet (1000Base-T) port, 2 FireWire (IEEE-1394a compliant) ports, 1 EIO Jetdirect accessory slot; scanner: 1 Fast Ethernet (100Base-T) port, 1 FireWire (IEEE-1394a compliant) port
Print languages, standard
Adobe PostScript 3; Adobe PDF 1.5; TIFF; JPEG; HP-GL/2; HP-RTL; CALS G4
Paper Handling
Document finishing
Printer: two automatic roll feeds; automatic rollswitching; automatic cutter; scanner: straight-through scan paper path for sheet and cardboard originals
Media types
Printer: bond and coated paper (bond, coated, heavyweight coated, super heavyweight plus matte); technical paper (natural tracing, translucent bond, vellum); film (clear, matte, polyester); photographic paper (satin, gloss, semi-gloss, matte, high-gloss); proofing paper (semi-gloss, semi-gloss contract); self-adhesive (indoor paper, polypropylene, vinyl); banner and sign material (outdoor paper, blue back billboard paper); scanner: non-abrasive paper, vellum, Mylar, sepia, blueprints, plastic, film, plastic laminate, foam board, cardboard (No plywood, stone plates, metal plates or abrasive, dirty, rough, sharp edged, metal clamped, or burned surfaces or transparencies)
Rolls External Diameter
7.08 in
Media thickness (by paper path)
Up to 15.7 mil
Scanning
Linear scan speed
Up to 3 in/sec (color, 200 dpi/400 dpi Turbo); up to 10 in/sec (black-and-white, 200 dpi/400 dpi Turbo)
Scan resolution color (best)
300 x 300 dpi
Scan resolution, optical
Up to 508 dpi
Scan resolution, hardware
Up to 508 x 508 dpi
Scanner type
Sheetfed
Scan size, maximum (flatbed)
42-in wide
Copying
Copy reduce/enlarge settings
1 to 10000%
Maximum number of copies
Up to 1000 copies
Compatible operating systems
Microsoft® Windows® 7 ready. For more information go to http://www.hp.com/go/windows7, Windows Vista (32-bit & 64-bit); Windows Server 2008 (32 and 64-bit); Windows XP Home and Professional (32 and 64-bit); Windows Server 2003 (32/64 bit)Windows Vista (R) (32 and 64-bit); Windows Server 2008 (32 and 64-bit); Windows XP Home and Professional (32 and 64-bit); Windows Server 2003 (32/64 bit); Mac OS X v 10.4; Mac OS X v 10.5; Linux (see http://www.hplipopensource.com)
Dimensions and weight
Dimensions, max. (W x D x H)
Printer: 76 x 31.5 x 53.2 in; scanner: 70.8 x 40.2 x 54.3 in
Product weight
408 lb
What's included
What's in the box
Printer; 42-in printer stand and bin; printheads (x8); printhead cleaners (x8); introductory ink cartridges; roll module; user maintenance kit; quick reference guide; setup poster; Serif PosterDesigner Pro poster; documentation and drivers software; scanner; touchscreen (panel PC); keyboard; scanner documentation CD; system recovery DVD; customer service guide; FireWire cables (x2); Ethernet cable; power cords
Software included
Warranty
One-year limited hardware warranty
حمل البورشور:
http://www.akiradata.co.id/brosur/HP Designjet 4520 edit.pdf
