Be a Leak Detective for Fix a Leak Week
by Kimberly Scharl
Did you know that easy-to-fix water leaks account for more than 1 trillion gallons of water wasted each year in US homes?* And every year, the average household leaks more than enough water to fill a school bus. These leaks not only waste a precious resource, but they could also be costing you an extra 10% on your water bill each month.
Good news! Fixing these leaks can be easy and inexpensive.* EPA’s WaterSense program encourages everyone to be a leak detective and “chase down” plumbing leaks during the 8th annual Fix a Leak Week. Start by gathering clues that will help you detect leaks in your home:
  • Check your utility bill – Look at your bill from January or February.* If a family of four exceeds water use of 12,000 gallons during a winter month, it’s likely there is a leak.* You can also examine your water bill for unexplained spikes from month to month.
  • Read your water meter – Find your water meter and remove the lid.* Take a reading during a period no water is being used, then take another reading in 2 hours.* If the second reading is not the same as the first, you probably have a leak.
  • Take a toilet test – Put a few drops of food coloring into the toilet tank and let it sit for 10 minutes.* If color shows up in the bowl, you have a leak that can probably be repaired with a new toilet flapper.* Make sure to flush after the test to avoid staining.
A good leak detective knows that leaks can be hiding in other places, too. Here are a few places you might want to investigate:
  • In the bathtub – Turn on the tub and divert the water to the showerhead.* If there is still a lot of water coming from the tub, your tub spout diverter may need to be replaced.
  • Under the sink – Check for pooling water under pipes and rust around joints.
  • Around the water heater – Check beneath the tank for pooling water, rust, or other signs of leakage.*
  • At the hose outside – If there are stray sprays, check the hose connection to the spigot, or try replacing the hose washer.
When replacing fixtures, remember to look for the WaterSense label.* WaterSense labeled products are independently certified to use at least 20 percent less water and perform as well or better than standard models.
Celebrate Fix a Leak Week by chasing down leaks in your own home. Leak detectives can tweet out the news of leak repairs using #Ifixleaks.
About the Author: Kimberly Scharl joined EPA in 2010, after moving to the mid-Atlantic region from Mississippi. She is a financial analyst and project officer in the Office of Infrastructure and Assistance, and is the regional liaison for the WaterSense Program. Kim enjoys bowling and spending time with her family.
