ArcGIS Runtime SDK for Xamarin Quartz Tech Preview is now available!
We are excited to announce the Quartz Tech Preview of ArcGIS Runtime SDK for Xamarin!* This SDK enables .NET developers to build immersive, native mapping applications for iOS and Android devices using C#.* It includes three APIs; Xamarin.iOS and Xamarin.Android for apps that need access to native functionality, and Xamarin.Forms to create shared UI layouts*across iOS and Android. *All are built on the same ArcGIS Runtime .NET API so they share a common design which encourages sharing code across application platforms.
Here is what you can expect to do in the Quartz Tech Preview of ArcGIS Runtime SDK for Xamarin:
  • Open, edit, and author web maps from ArcGIS Online and Portal for ArcGIS
  • Open ArcGIS mobile map packages containing maps, layers, locators, and networks
  • Display layers that use ArcGIS services (tiled and dynamic map image layers, vector tiled layers, feature layers)
  • Edit feature layers online and offline using geodatabase feature tables and the geodatabase sync task
  • Work with anonymous and secured portals
The Tech Preview is open to the public. *To learn how to get started, go to*the ArcGIS for Developers web site and join the*Tech Preview.*
Enjoy!
