3DF Zephyr Pro and 3DF Zephyr Aerial 2.306
3DF ZEPHYR ALLOWS YOU TO AUTOMATICALLY AND EASILY RECONSTRUCT 3D MODELS FROM PHOTOS
The process is completely automatic.
No coded targets, manual editing or special equipment are needed.
3DF Zephyr is built on top of our proprietary, cutting-edge, reconstruction technology.
3DF Samantha
Our Structure from Motion pipeline is able to automatically recover the relative cameras positions and orientation along with a sparse reconstruction of the scene directly from a set of casual images. Our core technology – codename Samantha – is known in the scientific community as one of the most effective and advanced. Part of our work has been published in top tier international computer vision conferences.
Key Features:
  • NVIDIA CUDA Technology (where available), multiple cores and SSE4 optimization.
  • Fully automatic camera orientation process.
  • Tree-based reconstruction to handle an high number of photos.
  • Completely auto calibrated: manual camera calibration is not needed.
3DF Stasia
3DF Stasia is the codename of our proprietary algorithm to extract a very accurate high-poly mesh from a set of 2d images. In computer vision this process is best known as Multiview Stereo. Our technology closely speaks with Samantha, our structure and motion pipeline, to give the most accurate reconstruction as possible. We stressed accuracy and we do make use of every single pixel of the input images to generate the 3d surface. The obtained solution is in all probability the most accurate, completely automatic, best engineered multiview-stereo algorithm available on the market.
Key Features:
  • Fully automatic dense reconstruction.
  • Accuracy driven reconstruction.
  • Built on top of Samantha, our leading Structure from Motion technology.
3DF Sasha
3DF Sasha is the codename of our proprietary algorithm for mesh extraction: given a dense point cloud full of details, it is important to preserve as much detail as possible when extracting the surface. Also while developing 3DF Sasha we stressed accuracy among other things. The algorithm is in the final part of development and testing, and it will be introduced in Q2 2015.
Key Features:
  • Detail preserving surface generation.
  • Every point count.
  • Sharp edges.
3DF Lapyx
3DF Lapyx is a free software utility to perform automatic camera calibration, that extracts the typical intrinsics camera parameters used in Computer Vision.
The software can extract and export the camera focal length (in pixels and mm), optical center, skew, and radial distortions parameters (using the Brown’s model).A simple wizard will guide you into the phase of camera calibration. All you have to do is take some pictures of a checkerboard grid, everything else is automatic.The software run on Windows, and comes in both 32-bit and 64-bit versions.
JLinkage
Linkage is a robust method for multiple models fitting.
The method is based on RANdom SAmpling as in RANSAC. We defined the novel concept of preference set (PS) of each point, i.e., the set of models that are satisfied by the point within a tolerance. Points belonging to the same structure will have similar PS, in other words, they will cluster in the conceptual space. The J-linkage algorithm proceed with an agglomerative clustering procedure that link elements with Jaccard distance smaller than 1 and stop as soon as there are no such elements left. We developed also an improved version that is able to work in an incremental way with an online framework.
According to Google Scholar, the original paper has already been cited more than 150 times. You can download the complete source code of the method below.
References:
  • R. Toldo and A. Fusiello. Photo-consistent planar patches from unstructured cloud of points, In Proceedings of the European Conference on Computer Vision (ECCV 2010), 2010. (PDF)
  • R. Toldo and A. Fusiello. Real time Incremental J-Linkage for Robust Multiple Structures Estimation, 3DPVT 2010 Conference. (PDF)
Quantel Synthia
In partnership with Quantel, 3Dflow took part at the development of SynthIA, a software package that provides professional high quality Stereo3D Interaxial adjustment in Post-processing.
SynthIA provides a complete suite of high quality Stereo3D manipulation tools that help users deliver compelling, high quality S3D results.
SynthIA tools include: Multiple display modes; Analytical tools (Luma/Chroma maps, Vectorscope, Disparity maps and Z-view); Color match (balances left and right eye color differences); Geofix (removes left and right eye geometry differences); Interaxial adjustment (changes the apparent camera interaxial distance after the shoot) and Z-warp (modify the Z composition of the shot).
3DF Zephyr Pro 2.306:
Direct link:http://mirror.3dflow.net/Zephyr/3DF%20Zephyr%20Pro%20v2.306%20(x64).exeMedicine Pro:
https://www.sendspace.com/file/taxyqePassword: countryboy 3DF Zephyr Aerial 2.306:
Direct link:http://mirror.3dflow.net/Zephyr/3DF%20Zephyr%20Aerial%20v2.306%20%28x64%29.exeMedicine Aerial:
https://www.sendspace.com/file/r7wd5yPassword: countryboy Thank you to countryboy for his fantastic work and share!!!
darksabersan.
