Zoom to selected features with ArcObjects
I am trying to figure out what is the best way to set the active view extent to be able to view all the selected features on the Arc Map.
1.The Map has only one layer.2.The features are filtered with attributes.
Below is the code where I tried,stuck with the part where I can loop through the features in the feature selection set but not able to set the active view extent to zoom to show all the selected ones.
P.S: this is similar to doing the right click on the attributes table and selecting multiple rows and doing a Zoom to selected.
private void ZoomToMultipleDGVSelection(List selectedRightIDs) { IMxDocument pMxDoc = ArcMap.Document; IMap pMap = (IMap)pMxDoc.ActiveView; ESRI.ArcGIS.Carto.ILayer layer = GetLayersClass.GetFieldBoundaryLayer; if (layer is ESRI.ArcGIS.Carto.IGroupLayer) { ESRI.ArcGIS.Carto.IGroupLayer groupLayer = layer as ESRI.ArcGIS.Carto.IGroupLayer; ICompositeLayer pCompositeLayer = layer as ICompositeLayer; int layers = pCompositeLayer.Count; ILayer pLayer = pCompositeLayer.Layer[0]; IFeatureLayer pFeatureLayer = (IFeatureLayer)pLayer; IFeatureSelection pFeatureSelection = (IFeatureSelection)pLayer; ISelectionSet pSelectionSet = pFeatureSelection.SelectionSet; IFeatureClass pFeatureClass = pFeatureLayer.FeatureClass; IQueryFilter pFilter = new QueryFilterClass(); foreach(int ID in selectedRightIDs) { pFilter.WhereClause = "RightID = " + ID.ToString(); IFeatureCursor pFeatureCursor = pFeatureClass.Search(pFilter, false); IFeature pFeature = pFeatureCursor.NextFeature(); pFeatureSelection.Add(pFeature); } //if (pFeature == null) //{ // System.Windows.Forms.MessageBox.Show("This section doesn't exist"); // return; //} IGeometry pgeom = (IGeometry)pFeature.Shape; pMap.SelectByShape(pgeom, null, false); IEnvelope pEnv = pgeom.Envelope; pMxDoc.ActiveView.Extent = pEnv; pMxDoc.ActiveView.Refresh(); } }Thank you in advance!
