Z and M values get lost when extending MS SQL geography Linestring by .STUnion
I'm trying to add new geography points with Z and M values to a geography linestring.This has to be SQL 2008 R2 compatible.
I've found some references to .STUnion() and tried that. The linestrings get combined but the Z and M values are lost.
Any ideas why this is happening or suggestions how to do this instead?
Thank you!
See example sql below (I do most of this in a series of functions, but the result is the same)
DECLARE @Linestring AS sys.geographyDECLARE @LinestringExt AS sys.geography --temporary linestring to extend @Linestring--Declaring and setting 3 geography pointsDECLARE @Point1 AS sys.geography = geography::STPointFromText('POINT(' + LTRIM(STR(15.444444,9,6)) + ' ' + LTRIM(STR(54.333333,8,6)) + ' ' + LTRIM(STR(10)) + ' ' + LTRIM(STR(1)) + ')', 4326)DECLARE @Point2 AS sys.geography = geography::STPointFromText('POINT(' + LTRIM(STR(13.222222,9,6)) + ' ' + LTRIM(STR(43.222222,8,6)) + ' ' + LTRIM(STR(20)) + ' ' + LTRIM(STR(2)) + ')', 4326)DECLARE @Point3 AS sys.geography = geography::STPointFromText('POINT(' + LTRIM(STR(12.111111,9,6)) + ' ' + LTRIM(STR(32.111111,8,6)) + ' ' + LTRIM(STR(30)) + ' ' + LTRIM(STR(3)) + ')', 4326)--Return Points to validate Z and M data is thereSELECT 'Point1' AS 'Point', @Point1.STAsText() AS 'STAsText', @Point1.ToString() AS 'ToString', @Point1.AsTextZM() AS 'AsTextZM()'--Point STAsText ToString AsTextZM()--Point1 POINT (54 15) POINT (54 15 10 1) POINT (54 15 10 1)SELECT 'Point2' AS 'Point', @Point2.STAsText() AS 'STAsText', @Point2.ToString() AS 'ToString', @Point2.AsTextZM() AS 'AsTextZM()'--Point STAsText ToString AsTextZM()--Point2 POINT (54 15) POINT (54 15 10 1) POINT (54 15 10 1)SELECT 'Point2' AS 'Point', @Point3.STAsText() AS 'STAsText', @Point3.ToString() AS 'ToString', @Point3.AsTextZM() AS 'AsTextZM()'--Point STAsText ToString AsTextZM()--Point2 POINT (54 15) POINT (54 15 10 1) POINT (54 15 10 1)--JOIN @Point1 and @Point2 to a LinestringSET @Linestring = geography::STLineFromText('LINESTRING(' + CAST(@Point1.Long AS varchar(32)) + ' ' + CAST(@Point1.Lat AS varchar(32)) + ' ' + LTRIM(STR(@Point1.Z)) + ' ' + LTRIM(STR(@Point1.M)) + ',' + CAST(@Point2.Long AS varchar(32)) + ' ' + CAST(@Point2.Lat AS varchar(32)) + ' ' + LTRIM(STR(@Point2.Z)) + ' ' + LTRIM(STR(@Point2.M)) + ')', @Point1.STSrid)--Return @Linestring to Z and M data is thereSELECT 'Linestring' AS 'Line', @Linestring.STAsText() AS 'STAsText', @Linestring.ToString() AS 'ToString', @Linestring.AsTextZM() AS 'AsTextZM()'--Line STAsText ToString AsTextZM()--Linestring LINESTRING (54 15, 43 13) LINESTRING (54 15 10 1, 43 13 20 2) LINESTRING (54 15 10 1, 43 13 20 2)--Add @Point3 to @LinestringSET @LinestringExt = geography::STLineFromText('LINESTRING(' + CAST(@Linestring.STEndPoint().Long AS varchar(32)) + ' ' + CAST(@Linestring.STEndPoint().Lat AS varchar(32)) + ' ' + LTRIM(STR(@Linestring.STEndPoint().Z)) + ' ' + LTRIM(STR(@Linestring.STEndPoint().M)) + ',' + CAST(@Point3.Long AS varchar(32)) + ' ' + CAST(@Point3.Lat AS varchar(32)) + ' ' + LTRIM(STR(@Point3.Z)) + ' ' + LTRIM(STR(@Point3.M)) + ')', @Linestring.STSrid)--Return @LinestringExtSELECT 'LinestringExt' AS 'Line', @LinestringExt.STAsText() AS 'STAsText', @LinestringExt.ToString() AS 'ToString', @LinestringExt.AsTextZM() AS 'AsTextZM()'--Union @Linestring and @LinestringExtSET @Linestring = @Linestring.STUnion(@LinestringExt)--Return Extended @LinestringSELECT 'Linestring (Ext)' AS 'Line', @Linestring.STAsText() AS 'STAsText', @Linestring.ToString() AS 'ToString', @Linestring.AsTextZM() AS 'AsTextZM()'--Line STAsText ToString AsTextZM()--Linestring (Ext) LINESTRING (12.1111 32.1111, 13.2222 43.2222, 15.4444 54.3333) LINESTRING (12.1111 32.1111, 13.2222 43.2222, 15.4444 54.3333) LINESTRING (12.1111 32.1111, 13.2222 43.2222, 15.4444 54.3333)
