Workspace or data source is read only
I am using ModelBuilder in ArcCatalog 10.1 to convert an ASCII files to TIFF and add spatial reference. I have hundreds of files to convert so I'm using the Iterators. After doing 10-20 files successfully I get the following error.
Executing (ASCII to Raster): ASCIIToRaster "D:\Users\Documents\#Data\# New Data\LIDAR\todo\nz4626_dsm_1m.asc" "C:\Users\Data\# New Data\Lidar2.gdb\nz4626_dsm_1m" FLOAT Start Time: Thu Aug 15 14:59:06 2013 ERROR 999999: Error executing function. Workspace or data source is read only. Workspace or data source is read only. No spatial reference exists. ERROR 010067: Error in executing grid expression. Failed to execute (ASCII to Raster). Failed at Thu Aug 15 14:59:06 2013 (Elapsed Time: 0.00 seconds) After using command prompt to remove read only tag from the source and destination folders and restarting ArcCatalog the process can be run again for a few more files before failing again.
What is causing the folders to become read only and how do I stop it?
