With schema function postgis_full_version() does not exist
A rails application is configured to run with postgis. Database.yml is configured as follows:
development: adapter: postgis database: app_development username: simpleton schema_search_path: public, postgisfor the schema search path, the attempt is to ensure that postgis is not installed twice by enacting as follows
app_development=#
DROP EXTENSION PostGIS;CREATE SCHEMA postgis;CREATE EXTENSION PostGIS WITH SCHEMA postgis;GRANT ALL ON postgis.geometry_columns TO PUBLIC;GRANT ALL ON postgis.spatial_ref_sys TO PUBLIC;which generates the error
ERROR: function postgis_full_version() does not existLINE 1: SELECT PostGIS_full_version(); ^HINT: No function matches the given name and argument types. You might need to add explicit type casts.Oddly, if the configuration is without a schema, i.e.
schema_search_path: public, postgisCREATE EXTENSION PostGIS;the SELECT command runs and the database migration can occur.
Why is this behaviour apparently selective?
