I have created a model which will output two Excel tables (the green circles at the end) per state. I am using "Iterate Field Values" to go through each state to create the tables. While this gives me each table I need, the problem is that when a table is empty, the model STILL outputs a table for that state - with rows for every state (all input).
Goal:
1) to have NO table output if there is no data in the table
or
2) to output a table that has empty fields
I would prefer the latter option. For Iterate Field Values I tried both checking 'Skip Null Values' and leaving it empty. Neither resolved the issue.
Goal:
or
