windows can't open the file, v.in.ascii
I am using GRASS 7 for windows, and I'm having trouble running v.in.ascii, although I'm fairly sure I've run it successfully before. When I run v.in.ascii, I get an error: Windows can't open this file.
This happens through the command line and the gui. Other v.*.exe commands seem to run properly.
I thought maybe there was a path clash somewhere, so I generally cleaned up my path variable (e.g., removing OSGeo4W/bin). I also reinstalled GRASS 7. I searched GRASS bugs, but didn't find something similar. Other than that, I haven't been able to find anything on google to help explain this, and I've run out of ideas.
Recently, IT installed hard drive encryption software. This and a couple problems popped up about the same time, so I have a sneaking suspicion that it's related.
