why won't the view options for the attribute table under "data; existing file" window
I'm using the Trimble GeoXT and TerraSync version 5.3.
I'm in TerraSync under Data -> Existing File -> and chose a shapefile to open up and view. It immediately displays the attribute table, however, the only field displayed is "distance". When navigating to "options" -> "view", it will let me click on any of the other options including, number, name, label 1, label 2, update, and filter, as if it were to put a check mark next to it and display that field in the attribute table but it does not!
I know everything displays and all of my data is associated in map view when I click on the features. It just will not display the other attributes in the table. It is not just this one shapefile either, no matter what file I choose to open it displays the table the same.
It only started doing this when I just recently opened the shapefile and was curious with how things displayed in the attribute table so I navigated to options -> view, and un-checked everything except "distance" just to see what it would do. Now it will not let me re-check them.
I've tried a soft and hard reset.
