Why isn't my Hyperlinks saving in ArcGIS 10.2
I have a polygon layer and I have a joined table with a link to an excel document for each polygon. Under the "Display" tab in layer properties I check the "Support Hyperlinks using field:" box and select the joined field that my document link is in and choose "Document" as my link type, apply and OK. It works fine, the excel document opens when I click the polygon with the hyperlink tool as it should. Now when I save the .mxd file,close it and then open it again, my changes to the Hyperlinks are not saved. Any other changes I make are saving, my joined table is still there, but the "Support Hyperlinks using field:" is no longer checked.
Why would it not be saving this?
