why is python toolbox script not working standalone in PyScripter?
I am learning Python Toolboxes with PyScripter.
I have a test python toolbox that outputs a raster file. It works when run from ArcCatalog.
As I understand it, it should also run standalone within Pyscripter but when I run it, no output appears in the Python Interpreter, and no file is created in the target geodatabase. I also can't locate advice on how to make the messages appear within the Pyscripter window, as they do in ArcCatalog, eg to indicate the analysis has finished within PyScripter without having to check in ArcCatalog.
Any advice / ideas would be appreciated.
I am using ArcGIS Desktop 10.2.2
import arcpyimport osimport sysfrom arcpy.sa import *class Toolbox(object): def __init__(self): """Define the toolbox (the name of the toolbox is the name of the .pyt file).""" self.label = "Toolbox" self.alias = "" # List of tool classes associated with this toolbox self.tools = [Capacity]class Capacity(object): def __init__(self): """Define the tool (tool name is the name of the class).""" self.label = "Capacity" self.description = "Calculates capacity score " self.canRunInBackground = False def getParameterInfo(self): p0 = arcpy.Parameter( displayName="Cell size and extent", name="SAcell", datatype="DERasterDataset", parameterType="Required", category = "Default cell size and extent" , direction="Input") p0.value = os.path.join(os.path.dirname(os.path.dirname(__file__)),'ModelOutputs\ES1BaseMap\Outputs.gdb', 'SA010') p1 = arcpy.Parameter( displayName="Outputs", name="Outputs", datatype="DEWorkspace", parameterType="Required", category = "Default data location", direction="Input") p1.value = os.path.join(os.path.dirname(os.path.dirname(__file__)),'ModelOutputs\ES2Carbon_storage_regulation\Outputs.gdb') p2 = arcpy.Parameter( displayName="Scratch", name="Scratch", datatype="DEWorkspace", parameterType="Required", category = "Default data location", direction="Input") p2.value = os.path.join(os.path.dirname(os.path.dirname(__file__)),'ModelOutputs\ES2Carbon_storage_regulation\Scratch.gdb') # parameter list return [p0, p1, p2] def isLicensed(self): """Set whether tool is licensed to execute.""" return True def updateParameters(self, parameters): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" return def updateMessages(self, parameters): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return def execute(self, parameters, messages): """The source code of the tool.""" SAcell = parameters[0].valueAsText Outputs = parameters[1].valueAsText Scratch = parameters[2].valueAsText # set analysis environment e.g. extent, cell size, snap raster ext2 = arcpy.Describe(SAcell).extent arcpy.env.extent = ext2 cell1 = parameters[0].valueAsText arcpy.env.cellSize = cell1 arcpy.env.snapRaster = parameters[0].valueAsText # set all local variables used in this model analysis test = "test" out2 = os.path.join(Outputs, test) # set overwrite and scratch workspace arcpy.env.overwriteOutput = True arcpy.env.workspace = Scratch arcpy.CheckOutExtension('Spatial') messages.addMessage("Starting analysis") arcpy.CopyRaster_management(cell1, out2) del test, cell1 messages.addMessage("Analysis finished") return
