I am trying to load a layer from a postgis database, mapserver does not return anything. I think I have narrowed the problem down to the fact that the sql query mapserver is running is returning nothing. Does anyone have any idea why this might be?
Mapfile:
MAPCONFIG "MS_ERRORFILE" "/srv/portal/www/Mapservices/mapfiles/maplog.txt"debug 5 EXTENT 506599.271346329 5962705.19473941 526000.205491952 5988176.64534367 IMAGETYPE PNG SIZE 1600 800 IMAGECOLOR 255 0 1 STATUS ONWEB METADATA "wms_title" "TSA-Zones-WMS" "wms_onlineresource" "http://{ip}/cgi-bin/mapserv?map=/srv/portal/www/Mapservices/mapfiles/TSAZones.map&version=1.0.0&service=wms" "wms_srs" "EPSG:3005 EPSG:4269 EPSG:3857" "wms_enable_request" "*" "wms_feature_info_mime_type" "text/html" END QUERYFORMAT text/htmlENDPROJECTION "init=epsg:3005"ENDOUTPUTFORMAT NAME png DRIVER AGG/PNG MIMETYPE "image/png" IMAGEMODE RGBA EXTENSION "png" FORMATOPTION "GAMMA=0.75" TRANSPARENT ONENDLAYERdebug 5 NAME TSA_Zones PROJECTION "init=epsg:3005" END METADATA "wms_srs" "EPSG:3005" "title" "TSA Zones" "wms_title" "TSA Zones" "wms_include_items" "all" "gml_include_items" "all" END STATUS OFF TYPE POLYGON CONNECTIONTYPE POSTGIS CONNECTION "host=127.0.0.1 dbname=mapdb user=postgres password=postgres" DATA "geom from pgpoly" OPACITY 100 CLASS STYLE COLOR 200 200 200 OUTLINECOLOR 0 0 0 END ENDENDENDMapserver log file:
[Fri May 29 10:47:22 2015].637637 CGI Request 1 on process 13779[Fri May 29 10:47:22 2015].638512 msPostGISLayerOpen called: geom from pgpoly[Fri May 29 10:47:22 2015].638529 msPostGISLayerOpen: No connection in pool, creating a fresh one.[Fri May 29 10:47:22 2015].680970 msConnPoolRegister(TSA_Zones,host=127.0.0.1 dbname=mapdb user=postgres password=postgres,0xa2e2658)[Fri May 29 10:47:22 2015].680989 msPostGISLayerFreeItemInfo called.[Fri May 29 10:47:22 2015].681031 msPostGISLayerWhichShapes called.[Fri May 29 10:47:22 2015].681038 msPostGISParseData called.[Fri May 29 10:47:22 2015].681059 msPostGISRetrievePK called.[Fri May 29 10:47:22 2015].681069 msPostGISRetrievePK: select attname from pg_attribute, pg_constraint, pg_class where pg_constraint.conrelid = pg_class.oid and pg_class.oid = pg_attribute.attrelid and pg_constraint.contype = 'p' and pg_constraint.conkey[1] = pg_attribute.attnum and pg_class.relname = 'pgpoly' and pg_table_is_visible(pg_class.oid) and pg_constraint.conkey[2] is null[Fri May 29 10:47:22 2015].684293 msPostGISParseData: unique_column=id, srid=, geom_column_name=geom, table_name=pgpoly[Fri May 29 10:47:22 2015].684308 msPostGISBuildSQL called.[Fri May 29 10:47:22 2015].684317 msPostGISBuildSQLItems called.[Fri May 29 10:47:22 2015].684323 msPostGISBuildSQLItems: 0 items requested.[Fri May 29 10:47:22 2015].684328 msPostGISBuildSQLFrom called.[Fri May 29 10:47:22 2015].684333 msPostGISBuildSQLWhere called.[Fri May 29 10:47:22 2015].684337 msPostGISBuildSQLSRID called.[Fri May 29 10:47:22 2015].684340 msPostGISBuildSQLSRID: Building find_srid line.[Fri May 29 10:47:22 2015].684344 msPostGISBuildSQLSRID: Found table (pgpoly)[Fri May 29 10:47:22 2015].684349 msPostGISBuildSQLBox called.[Fri May 29 10:47:22 2015].684391 msPostGISLayerWhichShapes query: select encode(AsBinary(force_collection(force_2d("geom")),'NDR'),'hex') as geom,"id" from pgpoly where geom && GeomFromText('POLYGON((9783.93962050256 -4999593.14607681,9783.93962050256 -9783.93962050349,4999593.14607681 -9783.93962050349,4999593.14607681 -4999593.14607681,9783.93962050256 -4999593.14607681))',find_srid('','pgpoly','geom'))[Fri May 29 10:47:22 2015].695342 msPostGISLayerWhichShapes query status: PGRES_TUPLES_OK (2)[Fri May 29 10:47:22 2015].695355 msPostGISLayerWhichShapes got 0 records in result.[Fri May 29 10:47:22 2015].695369 msPostGISLayerNextShape called.[Fri May 29 10:47:22 2015].695374 msPostGISLayerFreeItemInfo called.[Fri May 29 10:47:22 2015].695378 msPostGISLayerClose called: geom from pgpoly[Fri May 29 10:47:22 2015].695382 msConnPoolRelease(TSA_Zones,host=127.0.0.1 dbname=mapdb user=postgres password=postgres,0xa2e2658)[Fri May 29 10:47:22 2015].695389 msConnPoolClose(host=host=127.0.0.1 dbname=mapdb user=postgres password=postgres,0xa2e2658)[Fri May 29 10:47:22 2015].695559 msDrawMap(): Layer 0 (TSA_Zones), 0.057s[Fri May 29 10:47:22 2015].695578 msDrawMap(): Drawing Label Cache, 0.000s[Fri May 29 10:47:22 2015].695585 msDrawMap() total time: 0.058s[Fri May 29 10:47:22 2015].708344 msSaveImage() total time: 0.013s[Fri May 29 10:47:22 2015].708431 mapserv request processing time (msLoadMap not incl.): 0.071s[Fri May 29 10:47:22 2015].708444 msFreeMap(): freeing map at 0xa226e28.[Fri May 29 10:47:22 2015].708449 msPostGISLayerClose called: geom from pgpoly[Fri May 29 10:47:22 2015].708464 freeLayer(): freeing layer at 0xa22e898.[Fri May 29 10:47:22 2015].708468 msPostGISLayerIsOpen called.
Mapfile:
